Hello Guest it is November 09, 2026, 04:23:28 PM
Author Topic: Mach 3 generates sound "gong" signals into my PC repro  (Read 8501 times)
« on: May 01, 2014, 03:29:16 AM »
If I run some GCode programs, mach3 generates gong souns quite often ( almoust every input Gcode line ... ) .Its same signal as you can hear sometime (why not every time ?) if you press Mach3 Reset button.
I see that this sound is generated every time when Status text line is changed ( my G code input lines are with comments  in brackets and these comments are showed there in status line , however, curious is that not all comments, just some of them ....) .
What is the meaning of this - is it some kind of error message this song, or notification that status is changed ? Should I ignore it ? Is there any way to switch it off in Mach Setup  ?
Offline ZASto
  •  434 434
Re: Mach 3 generates sound "gong" signals into my PC repro
« Reply #1 on: May 01, 2014, 03:36:12 AM »
Take out the comments from your G Code :)
My personality is who I am.
