Hello Guest it is September 21, 2026, 02:08:08 PM
Author Topic: Rotary moves  (Read 16763 times)
Offline Keith
  •  187 187
Rotary moves
« on: February 23, 2006, 10:48:58 AM »
My 'g-coding' is coming along nicely.On many compound moves that also contain an 'a-axis' move ,I get reasonable velocity.I was under the impression that I could do a g01 'a'-n alone and could get the speed up...but that doesn't happen even with a rather large 'F'.So I went back to a little test code that Brian showed me to check repeatability on the a-axis.His code just said: 'a'-n(no G-anything)alone on a 'block'; and the axis screams(in a good way) and bingo,right on the money in terms of repeatability.Is saying just : 'a'-n equivalent to a G0 for this axis?
Re: Rotary moves
« Reply #1 on: February 23, 2006, 12:53:58 PM »
IIRC,
  Most G codes are modal. When you call one, it remains active until another cancels it out. Ie, G90 cancels out a G91 (abs, inc)
So, the code you have might have a G0 further up the line, making it feasible to just call out A0.
If it ain't broke, modify it!
Offline Keith
  •  187 187
Re: Rotary moves
« Reply #2 on: February 23, 2006, 12:58:32 PM »
Ah yes,you are so correct.Thanks,I'm getting there
Re: Rotary moves
« Reply #3 on: February 24, 2006, 04:35:29 AM »
I'm like a blind mouse...Every once in a while, the blind mouse gets the cheese. ;)
