Hello Guest it is September 24, 2026, 03:34:42 PM
Author Topic: Camsoft - Galil DMC-1850 - stuck  (Read 28650 times)
« on: April 24, 2014, 06:35:25 PM »
Making the move from Camsoft to Mach3. I have a Bridgeport Series 2 that has been running since 2003 with the Camsoft, however I need a change :)  for all the reasons others have posted.
Current setup is a DMC1850 with 2 ICM-1900, the Camsoft pendant and steppers. The machine is completely wired and for the most part runs fine. So the motor drivers, limits, etc are all hooked up. For now all I want to do is use the encoder on the pendant for testing. It is hooked up to aux 4 on the Galil.
I have SmartTerm, the Galil plugin and Mach3 installed. The plug in recognizes the board. I think I  remember that Camsoft had installed a driver for the board. Does it cause a conflict?
I have followed the docs in the plugin as far as mapping the axis and the connections for the limit switches. Now I am stuck, nothing moves. Any quick pointers? What do most people miss? Even though the hardware was working should I test for movement in Smart Term?
Thanks!
Offline smurph
  •  1,575 1,575
Re: Camsoft - Galil DMC-1850 - stuck
« Reply #1 on: April 25, 2014, 12:17:11 AM »
I have no idea how Camsoft was running the Galil.  But the drive should be the same as the one from Galil.  So I don't think that is the problem.  Yes, try movement in the SmartTerm first.
Also, you can enable debugging in the Galil plugin.  It generated a GalilDebug.txt file in the plugins directory.  Enable debugging, then restart Mach, then exit out of Mach and post the resulting Galildebug.txt file.
Steve
« Reply #2 on: April 25, 2014, 09:25:27 AM »
I started over with the configs, I think i missed the "save config" at the bottom. I'ts working now. I think I just needed to take a break and hit it again.
Thanks for help, I'm sure i will need more soon!!
