Hello
Guest
it is
October 20, 2026, 07:48:51 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Axis Problem
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Axis Problem (Read 22286 times)
Carnoustie, Scotland
Re: Axis Problem
Reply #10 on:
April 19, 2014, 11:38:54 AM »
I see you are using an external controller.
I am fairly certain that your external controller will need to support slaved homing for this to work correctly, reason I say that is because I remember the SmoothStepper having slaved axis homing problems at one time.
I think most likely your problems are with this, so possibly contact the vendor and see if they can shed any light on whether the controller supports slaved homing and how to set it up.
Logged
piccyman
37
Re: Axis Problem
Reply #11 on:
April 19, 2014, 12:28:29 PM »
Thank you Hood, I have sent them an email today.
I swapped the motor drivers over Y axis with the A axis , and strangely enough it has started working, will do more testing later to see if its reliable.
Thank you for your help
Logged
piccyman
37
Re: Axis Problem
Reply #12 on:
April 19, 2014, 02:59:28 PM »
I also wound down the amps on the Nema 23's to 1.8A, all seems to be working well now
Logged
Print
Pages:
1
2
Go Up
« previous
next »
