Hello Guest it is October 23, 2026, 12:52:53 AM
Author Topic: Mach3 wizard problem  (Read 10457 times)
Offline djk
  •  13 13
« on: April 17, 2014, 03:05:36 PM »
Hi
I had a old Demo mach3, every thing worked well. I updated and brought a license, now I have a problem with the wizards- cut circle - kiran.
First thing, when I have X center and Y center 0 the center is off to the side and the finish pass is off center. Second thing is circle Dia and tool Dia are wrong. I have to change these to circle radius and tool radius to get the right size circle.
If some one can help.
Thanks David
« Last Edit: April 17, 2014, 03:17:51 PM by djk »
Re: Mach3 wizard problem
« Reply #1 on: April 17, 2014, 04:27:57 PM »
You have the IJ mode set wrong, go to General Config and change it to Inc.
Offline djk
  •  13 13
« Reply #2 on: April 18, 2014, 05:40:06 AM »
Thanks Hood everything is working fine now.
David
