Hello Guest it is November 13, 2026, 02:03:07 PM
Author Topic: G-Code streaming VIA USB  (Read 38069 times)
Re: G-Code streaming VIA USB
« Reply #10 on: April 10, 2014, 01:38:35 PM »
Someone on the CamBam forum is using a board with GRBL firmware and discovered that it is woefully uner powered if the G-code contained arcs.
Do you know which Arduino was used ??
I have a feeling it was an older model that was an 8 bit unit that just doesn't have the computational power to take the G-Code and interpret it.
The newer DUE or the new TRE will be the ticket for sure, but will have to wait a bit for the RAMPS shield for the TRE.
« Reply #11 on: April 10, 2014, 02:18:53 PM »
Basicly what im saying is...
By being able to stream the Gcode, it would open up the door to more cheaper hardware for DIY or entry level enthusiasts where its not going to cost them an arm and a leg.
If all your interested in is basically a "toy" then yes.
I don't think you realize that there's a whole different DIY scene, where the Arduino type controls just won't cut it. There are thousands of people building midsize routers, that need the features and performance that Mach3 offers.
« Reply #12 on: April 10, 2014, 02:38:28 PM »
Yes, but those can still take advantage of the upcoming more powerful boards!
The boards only have 1 job:
Translate the G-Code to output pins of the processor.
All in all it becomes a bandwidth war...
Who can more more data and faster!
Actually its is to that point where you can send commands faster then they can be completed, hence why the rotary encoders are required on many machines as the motors are capable of skipping or missing steps and the encoders are there to follow the program along so it doesnt get ahead of itself rather then trying to guess which step is at on whichever axis.
« Reply #13 on: April 10, 2014, 03:10:59 PM »
The Smooth Stepper is capable of driving at 400KHz the stepper motor drivers.
The Arduino Due is capable of driving its digital outs at 12MHz ( Ben Hack on Youtube tested the Arduino Mega which is slower than the DUE and was able to hit 8MHz ) which is twenty times faster, however with the TRE and you even run Embedded mode under Linux or Android which would take it to a whole new level of development.
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #14 on: April 11, 2014, 07:44:39 AM »
Also I'm talking about a DIY level here with smaller table top machines, not people that converted older CNC or Non-CNC machines over.
OK so we're most likely talking about steppers then because if we're talking servo we wouldn't be concerned with $200 for a SS.
Not sure why you've latched onto the output switching speed as being of any particular importance to your point but as you have let's take a look...
Hmmmmm 12Mhz.... let's do the maths....
10 microsteps - so 2000 step/rev for your stepper motor (if you don't know why I've picked 10 then look it up)
12000000/2000 = 6000 revs/sec
multiply by 60 = 360000 - yes indeedy - that's a stepper doing THREE HUNDRED AND SIXTY THOUSAND rpm
Now that I'd like to see.
Let's take your figure for the SS
400000 / 2000 = 200
multiply by 60 = 12000 rpm
So let's come at it from the other way
I don't know what sort of definition you get with your repraps but would 100th of a mm be reasonable to discuss?
I pick that because it just happens to be the "theoretical" resolution of my router.
I have my rapids set to 10m/min - not unreasonable I'd have thought.
So at 10 microsteps that's 10000 * 100 = 1000000 steps/min or 16666 steps/sec i.e. ~16KHz. That's WELL within Mach's slowest kernel speed.
So please  ;D - make whatever points you like but let's have less of this nonesense about output switching speed.
« Reply #15 on: April 11, 2014, 04:51:09 PM »
No it doesn't, Mach 3 can already run faster through a parallel port than most machines require.
« Reply #16 on: April 11, 2014, 05:24:09 PM »
In my head... a USB interface is easier to use then the bulky DB25 and also makes it easier to deploy almost any cheap laptop on the market.
The EPP ( Enhanced Parallel Port ) is the main drawback and with the prices of other "mach" specific hardware isn't so DIY friendly.
That's total rubbish and demonstrates a fundamental misunderstanding of why Mach3 uses the parallel port, what it does with it and what a USB device needs to do to replicate that function - timing between different axes is critical - parallel data transfer permits this.
USB data transfer is fast but it doesn't deal well with timing and any USB hardware on the other end has to deal with this, you'd have to write the software to do it and the toys you're referring to just don't have the processing power to deal with the required data and timing for even a decent size of desktop machine running at reasonable speeds.
The Smooth Stepper can do the job because it's dedicated hardware & firmware that can't be programmed to do a myriad of pointless entertaining things, some knowlege of the history of computing (including the Apollo navigational computers, Space Shuttle computers) would help comprehension of what dedicated systems can do with modest processing power.
I find this attitude typical of the bottom end of the current breed of "Hackers" and "Makers" who can't do things manually and have little enough knowlege of the way things work at the lowest level to think they can assemble their dream of a quick, easy fix if they only connect the right set of high level systems together.
Heads up,
It ain't so ;-)
