Hello Guest it is November 13, 2026, 10:47:20 AM
Author Topic: A very NEWBIE question  (Read 9368 times)
jhb_in_seattle
« on: March 13, 2007, 03:28:51 PM »
Hello,
  I've been a long distance admirer of lathes and milling equipment. With the birth of my daughter, I find addressing those old desires again.
With that motivation, I started looking at some low cost options in the construction of a 3-axis CNC milling machine. I have only 3 questions, for now, to ask.
I've noticed that there are many free CAD and CAM options. My concern is with conductivity. Do all CAD programs provide a standard file type that all CAMs can use?
Do all CAM programs communicate through the NMC protocol?
G-Code is generated by the CAM process and that is sent to the motor drivers?
Any help would be greatly appreciated.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: A very NEWBIE question
« Reply #1 on: March 14, 2007, 04:09:55 AM »
All CAM programs store files in there own format, but most will import/export the standard file types e.g. iges, dxf.
The g-code generated must be formatted to the requirement of the controller (Mach) this is done by the post processor within the CAM software.
The g-code is then loaded into Mach and Mach converts the code into step/direction pulses and on/off signals.
Graham.
