Hello Guest it is October 22, 2026, 04:50:42 PM
Author Topic: Mach3 steppers stop on G76 - but not all the time  (Read 22369 times)
Offline Rimmel
  •  284 284
Re: Mach3 steppers stop on G76 - but not all the time
« Reply #10 on: May 24, 2014, 01:48:21 PM »
Oooooooooooh heres something interesting - when the program fails at the G76 line then it doesn't actually fail in the fact that the steppers do not work - it fails because mach3 fails to go into "mm/rev" mode. it stays in "mm/min" mode, so the steppers are moving but at a really slow rate as it is a 0.75 pitch thread so it's actually doing 0.75mm per minute!
Heres the test g-code.
G18 G21 G64 G80 G90 G40 G49 G94
GO Z50 X50
M0 ( TOOL 05 )
M3 S800
G0 G90 Z5 X9.84
G4 P1000
G76 X8.95 Z-21 Q2 P0.75 J0.03 L45 H0.05 I29 C0.3 B0.01 T0
G80 (CANCEL CANNED CYCLE)
G0 Z50 X50
M30
Any ideas?
thanks
Offline Rimmel
  •  284 284
« Reply #11 on: May 24, 2014, 02:28:49 PM »
Fixed it - I added "G95" just before the G76 line and it works fine now!
thanks
Offline 1Acnc
  •  28 28
« Reply #12 on: May 25, 2014, 02:09:44 PM »
I have a similar problem, If I stop the program and maybe re-Zero the Z ,that the DRO will sometime run but no stepper movement. I have found if I cycle the E-stop after making a change and then restarting, have not had the problem.  I am using a parallel port. I am new so I maybe doing things that I should not be doing.
Offline 1Acnc
  •  28 28
« Reply #13 on: May 25, 2014, 03:17:37 PM »
That should have been Reset not E-Stop
Offline Rimmel
  •  284 284
« Reply #14 on: May 25, 2014, 04:06:19 PM »
I found out the G95 trick because someone else had the same problem.
