Hello Guest it is October 05, 2026, 12:01:27 PM
Author Topic: Retrofit Bocsh cc100  (Read 9114 times)
Offline comet
  •  338 338
« on: March 12, 2007, 12:49:45 PM »
   hope someone can help!
Is it possible to retrofit a router which is controlled with a Bosch cc100,with mach3
  The router is a 1986 wadkin UX type.
I believe it is equipped with perm mag servo motors.
  Any help/info would be much appreciated.
   Tony
Re: Retrofit Bocsh cc100
« Reply #1 on: March 12, 2007, 10:41:37 PM »
You are going to need the specs off the motors and once you have that you can look at servo drives. Look at the drives from CNC Teknix drives (I think they will be about the right size also see if you can use GeckoDrives)
www.newfangledsolutions.com
www.machsupport.com
