Hello Guest it is November 02, 2026, 02:10:14 PM
Author Topic: New to Forum  (Read 36533 times)
Re: New to Forum
« Reply #20 on: March 17, 2014, 10:13:37 PM »
Just out of curiosity, close Mach, go to the Mach3 folder and double click on OriginalDriver.bat , then try to run the driver test.exe directly from the Mach3 folder.
Other than that, it might be a 7 thing, others will hopefully help.
Russ
Re: New to Forum
« Reply #21 on: March 17, 2014, 10:25:01 PM »
No dice.  There was a window associated with originaldriver.bat that said something about it being for Windows 2000.  Don't know if that's a problem or not.
Is there anyone on this forum that has successfully used Mach 3 with Windows 7?
My problem is that I can't get drivertest to run.
Re: New to Forum
« Reply #22 on: March 17, 2014, 10:30:35 PM »
I have ... no problem. Then went to an external controller for enhanced speed.
 Hang in there, you'll get sorted.
Russ
Re: New to Forum
« Reply #23 on: March 17, 2014, 10:32:23 PM »
I can hang in as long as you guys can. :)
Re: New to Forum
« Reply #24 on: March 18, 2014, 02:58:01 AM »
I am still curious about you saying YOU rebooted the first time, it should be automatic with Mach doing the reboot and nothing you can do about it.
Can you attach your xml.
I would also disable Norton to see if that makes a difference.
Re: New to Forum
« Reply #25 on: March 18, 2014, 04:35:13 AM »
Try this.
Go to the Mach3 folder - locate the driver test file.
Right click it.
Select Run as Administrator.
Windows 7 can have some odd file privileges that inhibit some files from running easily.
John Champlain
« Last Edit: March 18, 2014, 04:48:30 AM by Picengraver »
Re: New to Forum
« Reply #26 on: March 18, 2014, 07:59:04 AM »
That was it John.  I ran it in admin mode and it came right up and started working.  wow
Thank you all for the help.  I'll see you again when I run into the next issue.
BTW Hood, although I'm from Portland, Or, I've been to Carnoustie and played your wonderful golf course.  Beautiful part of the world.
rex
Re: New to Forum
« Reply #27 on: March 18, 2014, 02:41:44 PM »
I last played golf when I was 12, that was not yesterday sadly ;D
Re: New to Forum
« Reply #28 on: March 18, 2014, 03:57:30 PM »
I'm going to start a new thread for my next issue.
