Hello Guest it is October 25, 2026, 10:12:22 AM
Author Topic: Mach3 with Zenbot - Scaling Issue  (Read 8662 times)
« on: March 09, 2014, 10:20:25 PM »
My name is Jim and I am trying to use Mach3 with my Zenbot CNC machine.  I am encountering some issues, however.
I have creating a toolpath for my drawing in Vectric 2D and now want to use Mach3 to control my machine.  The guy from Zenbot gave me a pre-set profile for Mach3 that is made to work with this particular machine.  Also note that I am using a MachforWin64 kit and Windows 8.
My issue is that when I load the G-Cod on Mach3 and jog the machine, Mach3 shows that I have moved a certain distance, like 2mm, but the machine has actually moved way more than that (like a foot!)  Does anyone know what my problem is?
Thanks in advance,
Jim
Re: Mach3 with Zenbot - Scaling Issue
« Reply #1 on: March 11, 2014, 05:59:00 AM »
To use Mach3 with a 64bit OS an external motion controller, like a Smoothstepper, etc. must be used.
Are you are using one?
Also make sure that the your units are consistant for both Mach configuraton and Vetric and scale is set at 1.
« Reply #2 on: March 11, 2014, 08:50:19 AM »
Hi Rich,
Thanks for your help.  I figured out the issue.  I just had to reload the configuration sent to me by the CNC manufacturer.  Yes, I am using a MachforWin64 external motion controller.  Not really sure what was up with that but the problem seems to be fixed.
Thanks for your help,
Jim
