Hello Guest it is November 04, 2026, 11:45:34 AM
Author Topic: g-code won't run  (Read 11390 times)
g-code won't run
« on: March 09, 2014, 10:45:07 AM »
Hi all,
I'm struggling to get this g-code to run on Mach3 and I can't for the life of me see what's wrong with it. When I load it up, the shape doesn't appear in the view window. When I attempt to run it, Mach skips to the first G3 line and then stops the cycle. Any ideas?
Re: g-code won't run
« Reply #1 on: March 09, 2014, 10:53:46 AM »
Do you  get a message in the status line ?  "Radius to end differs ........" ?
Might need to change your I-J setting to Inc in gen config.
Russ
« Reply #2 on: March 09, 2014, 10:59:15 AM »
'radius to end of arc differs from radius to start. Block = G3 Y232.4269 I0.0 J88.0'
« Reply #3 on: March 09, 2014, 11:01:59 AM »
.................. change your I-J setting to Inc in gen config.
Russ
« Reply #4 on: March 09, 2014, 12:01:54 PM »
got it, thanks!
« Reply #5 on: March 09, 2014, 12:05:57 PM »
No problemo.
A very common issue .... and search topic.  :)
Russ
