Hello Guest it is October 14, 2026, 07:49:40 PM
Author Topic: Angle of rotation and reverse run problem...  (Read 15607 times)
« on: March 06, 2014, 04:45:00 AM »
Hi!
I face a problem, if you have seen it, please advice:
When angle of rotation (standard DRO 118) has any value,
when i hit "reverse run" to follow the path backwards (under G40),
the machine goes somewhere else (probably follows different angle).
I didnt have this problem until now, might be any settings or something?
Versions 3.043.066 and 067 have been tried.
Giannis
Re: Angle of rotation and reverse run problem...
« Reply #1 on: March 06, 2014, 07:23:36 AM »
Here's a print screen to show you what exactly is the problem.
There is already an angle while running.
When pause and reverse run is hit, the machine goes back with a different angle.
Have you seen that  before?
« Reply #2 on: March 12, 2014, 01:08:46 AM »
Any ideas?
« Reply #3 on: March 12, 2014, 03:09:14 AM »
I never use reverse run so cant really be of help I am afraid but possibly try an older version of Mach just in case it is one of the issues that has been introduced with 066.
« Reply #4 on: March 18, 2014, 01:09:53 PM »
The problem goes back down to version 3.043.53
It seems is old problem.
Please consider for the next version.
« Reply #5 on: December 15, 2014, 02:12:03 PM »
Hello Giannis,
Have you been able to solve this issue? I have the same problem.
Thanks.
Juan Carlos
« Reply #6 on: December 16, 2014, 03:51:45 AM »
No, I didn't solve it...
I just run the 3.043.53 version where it works.
Giannis
« Reply #7 on: December 16, 2014, 06:25:58 AM »
Thanks!
Best Regards,
Juan Carlos
« Reply #8 on: December 16, 2014, 07:30:17 AM »
Dear Giannis.
I've just tried the 3.043.53 version, but It didn't works too. I also tested the Version R3.042.029, without lucky. I wonder if there is another thing thats makes this problem to appear. Maybe have you changed anything else?
Thanks!
Juan Carlos
« Reply #9 on: December 16, 2014, 09:44:21 PM »
Juan, I'm working with pokeys.
So the best combination that worked for me was 3.043.53 and 3.0.65 firmware for pokeys.
I spent dozens of hours to find out why and how. Seems there won't be another bug fix for mach3.
Mach4 is already here.
