Hello Guest it is November 04, 2026, 09:06:54 AM
Author Topic: 'run from here' not working as expected  (Read 20813 times)
Re: 'run from here' not working as expected
« Reply #10 on: March 06, 2014, 07:33:03 AM »
Oh that's a shame. I'll go back to doing it the long clumsy way until I know for sure my machine is viable. At least I know it wasn't anything I was doing, its behaviour was totally baffling...
« Reply #11 on: March 06, 2014, 12:58:14 PM »
Demo does most things but there are some that only works in a licensed verson, here are the restrictions as published on the Artsoft info page.
Mill & Plasma: 500 line gcode limit (10,000,000 limit after licensing)
Turn: 50 line gcode limit (10,000,000 limit after licensing)
Kernel Frequency locked at 25kHz (only applicable if using the parallel port driver)
Set Next Line function disabled
Run From Here function disabled
Turn: Threading disabled
Plasma: THC functions disabled
« Reply #12 on: March 06, 2014, 01:05:46 PM »
Thanks, I'll definitely have to buy a licence at some point; I'm also waiting to find out what Mach 4 can do first...
