Hello Guest it is November 04, 2026, 09:09:22 AM
Author Topic: Slaving steppers  (Read 7543 times)
Slaving steppers
« on: February 27, 2014, 11:21:11 PM »
Could anyone here explain to me (a CNC router beginner) how to slave 2 steppers on the same axis ("Y") running one stepper reversed? (Thus both moving the gantry in the same direction.) I have 3 Geckodrive NEMA 23 steppers with a G540 control board.
« Last Edit: February 27, 2014, 11:26:35 PM by GrandpawB »
Re: Slaving steppers
« Reply #1 on: February 28, 2014, 06:30:50 AM »
Configure one of the motors as the A axis. Make sure all settings are the same as the Y axis motor.
Go to Config > Slave Axis, and slave A to Y.
To reverse one motors direction, either change the direction active low setting, or check the "Reverse" column in Config > Homing/Limits.
