Hello
Guest
it is
November 04, 2026, 09:14:21 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
home plus and minus = limit switches
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: home plus and minus = limit switches (Read 21734 times)
nobby
154
Re: home plus and minus = limit switches
Reply #10 on:
February 25, 2014, 04:08:02 PM »
another one i didn't realise.
if you have the soft limit set to 1cm
then you zero.
you have to have the offset at 1.1cm otherwise you get a soft-limit warning
i thought I was in the soft limit zone for the z axis all the time.
simply set my g54 to 1.1 and away!!
getting the hang of it now.
Logged
nobby
154
Reply #11 on:
February 28, 2014, 04:34:09 PM »
damn, they are mm's and not cm's in mach
I had everything times 10 on the motor tuning.
and times 10 in mach.
its correct now! 10 steps on the drives
400 steps per
2000 mm per
100 accel.
great, all I need do now is replace my x axis ball screw.
Logged
Print
Pages:
1
2
Go Up
« previous
next »
