Hello Guest it is November 13, 2026, 01:17:19 PM
Author Topic: Limit rapid speed from a digital input  (Read 23863 times)
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
Re: Limit rapid speed from a digital input
« Reply #10 on: February 18, 2014, 09:15:36 AM »
Ha ha but DRO 104 is Rapid Feedrate DRO which to me means it is showing the actual rate in Units per Min (if in G94) that the axis is moving after you have applied a Rapid Override % ;D
Ha ha ha back - but DRO 104 doesn't do that - well not on my system anyway.... Doesn't matter what % you set DRO 223 to it makes no difference to the value in DRO 104. HOWEVER if you PUT a value in DRO 104 AND click Button 287 then it will not only override the NEXT rapid rate it will override any override % set by 223.
Anyway for Gary if he writes to OEM 223,  with the % of his rapid that  he wants, it will do as he wants :)
As I said - you were and are correct. (As long as he doesn't override the rapid override...   ;))
Ian
« Reply #11 on: February 18, 2014, 10:31:06 AM »
Ha ha Ian, yes you are right, I looked to see what you were on about and it is a special function, I am not special so have never seen it ;D
 Must have been added at some point for someone, wonder what it was for, maybe someone had some weird application and wanted to just use rapids and have a way of setting it to one or another.
« Reply #12 on: February 18, 2014, 08:48:34 PM »
Thanks guys,
That sounds good, I think.
« Reply #13 on: February 18, 2014, 10:43:41 PM »
Who is on first. What is on second. I don't know is on third.  ;D
