Hello Guest it is November 25, 2026, 09:29:46 AM
Author Topic: Mach3 no longer controlling machine.  (Read 19807 times)
« on: February 15, 2014, 10:59:12 PM »
So I did some cutting last week.  Shut everything down as usual and walked outmost the shop. Walked back in today. Fired everything up and nothing. Can't jog with the keyboard, mouse, or mpg. The screen/dro shows everything moving but the maching is doing nothing. Timer is counting. I have a freq.  I'm kind of lost. Anyone have any idea what it could be??   Thanks in advance for any help.
Re: Mach3 no longer controlling machine.
« Reply #1 on: February 15, 2014, 11:13:29 PM »
Is there power to the drives and motors?
« Reply #2 on: February 15, 2014, 11:16:56 PM »
Yup control box is running and all the motors are live. Touch prob lights up and sends signal in diagnostics. I swapped out the pp cable. Uninstalled mach3 and reinstalled. Nothing.
« Reply #3 on: February 16, 2014, 04:40:53 AM »
attach your xml and I can check that.
« Reply #4 on: February 16, 2014, 08:43:33 AM »
Attached is my controller box xml.  Appreciate it.
« Reply #5 on: February 16, 2014, 11:34:21 AM »
I dont see anything wrong with your xml, assuming of course the correct port and pins are set.
If you look on the Diagnostics page do you see a Time in Int and a Frequency and is the Frequency close to the kernel you have set?
« Reply #6 on: February 16, 2014, 11:49:57 AM »
yea it hovers right aroun 45000 which is what its set at.  Time int is running as well.  I dont know what the deal is.
« Reply #7 on: February 16, 2014, 11:52:59 AM »
If you have a scope you can see if the pulses are coming out of the port, if no scope but a volt meter you could still check at least to see if Dir signals are coming out.
« Reply #8 on: February 16, 2014, 12:06:47 PM »
I have a meter. Check at the pp on the PC I take it?
« Reply #9 on: February 16, 2014, 12:11:11 PM »
Yes, you can remove the cable and check the Dir pin to Gnd pin and jog that axis back and forth and see if you get a change from 5v to 0v. You will likely have to change the active state of the E-Stop in Ports and Pins, Inputs so that you can get Mach out of Reset for the testing.
