Hello Guest it is November 22, 2026, 02:04:11 PM
Author Topic: Spindle Lock Error G76 Thread Cycle  (Read 40364 times)
Re: Spindle Lock Error G76 Thread Cycle
« Reply #10 on: February 10, 2014, 04:06:25 PM »
Run for a few passes then hit Cycle Stop.
Enclosed... ::)
« Reply #11 on: February 10, 2014, 04:07:36 PM »
Oh, ok I try again!
Just a minute...
« Reply #12 on: February 10, 2014, 04:16:54 PM »
Try These
« Reply #13 on: February 10, 2014, 04:18:43 PM »
Think I need a coffee now to keep going here :)
Thank you again,
LP
« Reply #14 on: February 10, 2014, 04:22:39 PM »
Ok go to ports and pins then Inputs and scroll down and disable Timing.
It is no longer used, used to be you could use that instead of Index if you had multiple slots but now only a single Index can be used with the parallel port.
« Reply #15 on: February 10, 2014, 04:27:32 PM »
BTW Updated my profile with the 5 hrs difference...so the time should now be international. :)
« Reply #16 on: February 10, 2014, 04:28:56 PM »
It was actually your error file I was looking at and thought it was the date but its the time I think :D
« Reply #17 on: February 10, 2014, 04:35:41 PM »
Also just looked in the xml and the Turn Diagnostics plugin is indeed turned on, must have been from an earlier install and you reused the xml.
You can either install an old version of Mach with the plugin so you can turn it off or you could open the xml in notepad or similar and change the value from 1 to 0.
The value will be as such
<TurnDiags-Turn-Diags-1.00.1>
1
</TurnDiags-Turn-Diags-1.00.1>
and it should be
0
« Reply #18 on: February 10, 2014, 04:48:00 PM »
Hi Hood,
Ok, done...the XML modification.
Checked the diags are off in the enclosed XML ...LP5.
Run produced results in error file ...LP5
Still producing erros, I recon it is a version thing as yoiu say!
Sorry but I must go to bed now as I have been up for over 16hrs...
Latest files enclosed...
Regard
LP
« Reply #19 on: February 10, 2014, 04:54:21 PM »
Are you actually having issues threading or is it just the last errors you are looking at?
