Hello
Guest
it is
November 17, 2026, 11:25:39 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Whats the best settings for a CNC3040 in Mach3?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Whats the best settings for a CNC3040 in Mach3? (Read 11571 times)
jokernippe
25
on:
February 10, 2014, 07:00:13 AM »
I'm new at this and I have som problems getting cnc to cut right, soiwonder if someone can tell me what would be the best settings for the cnc3040
Motor tuning, ports and pins and more.....
Thanks for the help!
Logged
Fastest1
920
Houston, TX
Re: Whats the best settings for a CNC3040 in Mach3?
Reply #1 on:
February 10, 2014, 08:32:46 AM »
Joker welcome to Mach.
When you say you are having some problems getting it to cut right, what do you mean? Is it cutting the wrong size? Losing steps and moving over in 1 or more axis and leaving what appear to be steps in the side walls of your parts?
Btw, Where are you located?
Logged
jokernippe
25
Reply #2 on:
February 10, 2014, 08:41:43 AM »
It is cutting in wrong size and when i'm doing a box so the first time it engraves abou 50x50mm and the second time 48x48mm...
Logged
Fastest1
920
Houston, TX
Reply #3 on:
February 10, 2014, 08:48:33 AM »
Have you used this machine before or are you new to it?
When you say the 1st and 2nd times are you referring to passes or attempts at getting the correct size?
Is you machine calibrated and moving properly? The correct tool diameter in the machine and in the CAM?
Logged
Fastest1
920
Houston, TX
Reply #4 on:
February 10, 2014, 08:52:03 AM »
Btw, Machines vary in their settings quite a bit. This can be from a multitude of reasons, gibs, sliding or rolling resistance, pitch of lead or ball screws, resonance from a microstepping value or lack of.
Logged
Print
Pages:
1
Go Up
« previous
next »
