Hello
Guest
it is
November 13, 2026, 09:35:49 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Sherline speeds direction transition
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Sherline speeds direction transition (Read 21679 times)
Re: Sherline speeds direction transition
Reply #10 on:
February 16, 2014, 05:28:42 AM »
Is there any benefit in adjusting the Gs?
Can't, as it's a calculated value based on you other settings.
Logged
Fastest1
920
Houston, TX
Reply #11 on:
February 21, 2014, 09:46:05 PM »
Were you running your backlash comp at 100%?
Logged
Craig1
47
Reply #12 on:
February 24, 2014, 04:03:37 PM »
Fastest1,
Yes i had backlash at 100. I had to do some further searching and didnt realize i was given the answer. My shuttle settings were too high. I adjusted to .0001 and all is smooth.
Thanks for the help gents.
Logged
Print
Pages:
1
2
Go Up
« previous
next »
