Hello
Guest
it is
November 24, 2026, 10:29:17 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Plasma torch settings via spindle....
« previous
next »
Print
Pages:
1
2
3
Go Down
Author
Topic: Plasma torch settings via spindle.... (Read 35236 times)
Carnoustie, Scotland
Re: Plasma torch settings via spindle....
Reply #10 on:
January 29, 2014, 07:49:08 AM »
Check direct at the port.
Logged
Davek0974
2,606
Reply #11 on:
January 29, 2014, 08:10:51 AM »
On the socket, comparing to pin25 as ground i have the following signals with mach running and reset ok but no outputs.....
1=High
2=High
3=Low
4=Low
5=Low
6=High
7=Low
8=High
9=Low
10=High
11=High
12=Low
13=High
14=High
15=High
16=High
17=Low
Make any sense?
Thanks for helping BTW.
Logged
Reply #12 on:
January 29, 2014, 08:23:23 AM »
You would need to operate an output to see whether it is working or not, so for pin 9 MDI M3 and the state should change, M5 and it should revert to original state.
Logged
Davek0974
2,606
Reply #13 on:
January 29, 2014, 08:29:32 AM »
Small update, if i shut down mach 3 then go into device manager and disable/re-enable the LPT port, the relay energises as all output pins 1-9 were reading high.
As soon as i load mach3 and press reset, the relay drops out and cannot be re-energised.
At least the port, lead and relay are proven working.
But what goes on when mach does a reset?
Logged
Davek0974
2,606
Reply #14 on:
January 29, 2014, 09:20:28 AM »
If i reboot the PC, when it comes back up, the spindle relay energises, as soon as mach3 is loaded, it drops out and I cannot get it to re-energise again.
Seems mach3 is not doing something right??
Logged
Davek0974
2,606
Reply #15 on:
January 29, 2014, 09:56:36 AM »
Just tried a fresh install on another PC, different make but exactly the same behaviour.
Logged
Reply #16 on:
January 29, 2014, 10:07:51 AM »
Change the active state of the output.
If that doesnt work attach your xml and I will take a look.
Logged
Davek0974
2,606
Reply #17 on:
January 29, 2014, 11:58:36 AM »
If by that you mean active high/low then yes I have tried.
The machine is at work so I will have to upload the file tomorrow.
Logged
Davek0974
2,606
Reply #18 on:
January 30, 2014, 02:16:18 AM »
FIXED!
There was a little post i found on a google search.
There is a tick box - "Max CL Mode Enabled", this was checked, unchecking solved the issue
Happy days, thanks for the help.
Logged
Reply #19 on:
January 30, 2014, 05:59:21 AM »
Yes that would do it
Max modes are for specific machines and they preset the I/O to dedicated pins which you can not change, even by setting pin numbers in Ports and Pins.
Logged
Print
Pages:
1
2
3
Go Up
« previous
next »
