Hello Guest it is November 04, 2026, 07:13:04 PM
Author Topic: Homing/Limits  (Read 15426 times)
Homing/Limits
« on: January 15, 2014, 01:52:48 PM »
Is there a way to home REF a CNC router table at X+ Y+ rather then the std. X- Y- location limit switch locations. I understand that machine coordinates would be in neg values. Trying this I get a homing/ limit min>max error when a try to ref. the machine.  The odd thing to is that the Y jog direction flips direction after REF axis. I'd assume I would set my limits a neg numbers as well. My table has a 98 inch X axis travel and a 52 inch Y axis. I'd like to park the gantry at the X+ Y+ location as it is out of the way in that corner of the shop. You can see the DIY router table on youtube just seach for "ShadeTreeCNC"   or a link http://www.youtube.com/user/ShadeTreeCNC any help would great!
Rich Moller
Re: Homing/Limits
« Reply #1 on: January 15, 2014, 04:01:58 PM »
If you go To Config > Homing/Limits, and uncheck "Home Negative" for those axis, then it will home positive.
If you set a Home Offset of 98 for the X and 52 for the Y, then your machine coordinates will be positive, with 0,0 in the lower left, but Home in the upper right
Re: Homing/Limits
« Reply #2 on: January 16, 2014, 02:58:40 PM »
Thanks for the reply that makes perfect sense. Now a follow on question: I can only assume that the soft limiits are in relation to the now zero / zero position and not the home position. So now do I need to have my work coordinate inside the soft limits area before toggling in on on the run screen? Soft limits set as .5 = min and 97.5 max for X axis and .5 = min and 51.5 max for Y axis. I'm also assuming I'd need to toggle soft limits off before REF home.
Re: Homing/Limits
« Reply #3 on: January 16, 2014, 05:20:36 PM »
Personally, I would modify the homing macro to do the following:
1) Turn off softlimits
2) Ref the axis
3) Move away from the switches inside the softlimit zone
4) Turn Softlimits back on.
Re: Homing/Limits
« Reply #4 on: March 16, 2014, 12:41:21 PM »
Is there a way to make 1 axis return to a user defined zero (work piece zero) without offsets.
Also, is there a way to wire in another limit switch that halts/stops the travel? I have proximity switches, not mechanical limit switches right now and when manually jogging I can go right past the switches and have already accidentally ran my slides off the linear rails, thus pulling oil lines out. I was able to get everything back together but I want to make this fully dummy proof for myself.
Whizbang
Offline Fastest1
  •  920 920
  • Houston, TX
Homing/Limits
« Reply #5 on: March 17, 2014, 08:09:43 AM »
The returning to zero is most likely achievable though I couldn't tell you how to do it.
In regards to the switches, proximity or other kinds. Do you have the switch enabled as a home switch? As a limit switch too? Both types will need to be enabled though you only run 1 physical switch. Look into running "soft limits" too. This will keep the machine within its physical boundaries.
Re: Homing/Limits
« Reply #6 on: April 23, 2014, 01:13:18 AM »
After many years of running my router I decided to add homing and limit switches. It seemed ok when I tested the switches and connections to Mach3, diagnostics shows homing OK.
But when I tried to use homing cycle, Z and Y were ok but X had a problem. There I have main X axis and B as a slave. For some reason slave is not driven during the homing cycle.
Gantry is not moving, just making terrible sound. Looking at the forum I did found some reference to this in 2007. I have downloaded the latest version R3.043.066 but it did not make
any difference. I assume there must be a solution to this issue. I hope someone can point me in the correct direction. Thanks
Re: Homing/Limits
« Reply #7 on: April 23, 2014, 02:18:29 AM »
Just found the solution to my question. There is a small window under General Logic Configuration which I did nit tick, This activates Home Slave  with Master :D
