Hello Guest it is November 18, 2026, 12:09:47 PM
Author Topic: checking jogging voltage pins  (Read 7705 times)
« on: January 13, 2014, 01:04:31 PM »
I need help in checking the Y axis jogging pin to check the voltage. when i jog it down arrow key it goes up, the up arrow key goes up.
thanks rod
Re: checking jogging voltage pins
« Reply #1 on: January 13, 2014, 02:50:48 PM »
Change the active state of the Y's Dir pin, in Ports and Pins, Motor Setup.
