Hello Guest it is November 14, 2026, 12:21:15 PM
Author Topic: Removed EMI, but still need debounce?  (Read 19676 times)
Re: Removed EMI, but still need debounce?
« Reply #10 on: January 03, 2014, 05:51:43 PM »
I used to work with a microprocessor driven product.  It is surprising how much mechanical switches can bounce on closing. I always wire limits, float switches, etc. to operate by opening, less bounce.  A broken wire looks like the limit is hit warning you that it isn't working. Otherwise you could crash into a non-functioning switch. A broken wire indicates a tank is full, warning you that it isn't working before you over fill it.  It pays to always think failsafe.
