Hello Guest it is November 03, 2026, 10:45:33 PM
Author Topic: Mirror milling  (Read 9710 times)
Mirror milling
« on: December 23, 2013, 09:15:33 AM »
I have mange to start cnc from China. But it mills teks wrong way. I am not DaVinci, so I would like to repair this. Does somebody knows whath to do.
Please help
  •  9,375 9,375
Re: Mirror milling
« Reply #1 on: December 23, 2013, 10:05:12 AM »
In Config / Ports & Pins / Motor Outputs change the 'Dir Low Active' state for the axis that is machining backwards
Re: Mirror milling
« Reply #2 on: December 23, 2013, 11:57:28 AM »
Thank you. the first letter word the mill make ok other again in mirror state.
Re: Mirror milling
« Reply #3 on: December 23, 2013, 12:35:20 PM »
It works Eureka. Thank you veary much once again.
Do you mybee know how to kontrol spindle in PWM mode. if I have on PWM mode it runs on full speed. komand M5 doesentz help.
You aree the men!!!!
Thanks once again on help.
Best regards,
Gregor
  •  9,375 9,375
Re: Mirror milling
« Reply #4 on: December 24, 2013, 01:11:18 AM »
Hi Gregor,
If you return to the main page and enter    pwm spindle control    in the search box it will throw up lots of information on how it has been done.
