Hello Guest it is November 13, 2026, 01:53:06 PM
Author Topic: Troubles with PWM output Voltage  (Read 33577 times)
Re: Troubles with PWM output Voltage
« Reply #20 on: January 12, 2014, 09:48:39 AM »
I definitely don't get 0 volts it's A constant 6.5 - 7volts   no matter what change is made enabled or disabled.
« Reply #21 on: January 12, 2014, 10:04:50 AM »
If you are shure you did the tests with port 1 not accedently wit port 2 then it looks like something is burned, but hard to say from a distance.
Alex
« Reply #22 on: January 12, 2014, 11:30:42 AM »
I use Port 2 for another breakout board and additional outputs for flood coolant and mist solonoid. And everything else works fine on g540, smooth stepper and c10 BB with no issues. But I do know that if the g540 vfd I/O gets smoked it it's isolated and won't effect anything else. I will ship it to gecko to test and fix the problem. Thank you very much for your help . Hopefully when It returns I can get this going.
