Hello Guest it is November 13, 2026, 12:15:49 PM
Author Topic: After homing axis don't back off Switches  (Read 23817 times)
Re: After homing axis don't back off Switches
« Reply #10 on: July 29, 2019, 01:52:49 PM »
Check to be certain that the limits and homes are mapped to the same input. For example, if X limit is mapped to Port 11, Input 1, then the X Home must also be mapped to Port 11, Input 1. I made the mistake of using a jumper to share the physical signal for X limits and X home instead of sharing the Port and had the same problem.
