Hello Guest it is October 20, 2026, 02:51:37 PM
Author Topic: X, Y, Z Getting mixed or different coordinates than given.  (Read 32457 times)
Re: X, Y, Z Getting mixed or different coordinates than given.
« Reply #20 on: December 12, 2013, 04:00:55 PM »
You dont have Z Depth Inhibit turned on do you?
« Reply #21 on: December 12, 2013, 04:55:54 PM »
No error occurred. Z inhibit is turned off.
« Reply #22 on: December 12, 2013, 05:19:01 PM »
Just command Z moves on their own from MDI.
Does the Is Still box in the SS monitoring have a check in it when it is going past 16 or does that just appear when Machs DRO gets to the 17 or 18 or whatever you have commanded?
If it is the latter then your problem doesnt seem to be Mach or SS as both are showing motion commands up until they are stopped.
« Reply #23 on: December 12, 2013, 06:00:21 PM »
Ok, heres what I finally found out.
Z Problem - Someone had moved the router head, and the bit wasn't clearing to our spoilage board. A part of the machine itself was touching the wood before the bit could go through. Thats why our z was off by 2mm.
X and Y Hopefully - I checked another thread of someone having the same issue and saying that it was the E - Stop switches that were not wired correctly, or poorly wired. So we undid all of the cover plates for them and checked the wires. We found some pinched wires under some E - Tape that we think might have been the issue. We re-wired them and everything seems to work fine. It will take some time to tell if it did the trick. But for now we are operational.
Thank you for your help Hood.
Austin
« Reply #24 on: December 13, 2013, 03:31:04 AM »
Hopefully thats you sorted :)
