Hello Guest it is November 14, 2026, 05:56:13 AM
Author Topic: Display value of Gcode variable on a DRO  (Read 9915 times)
« on: December 11, 2013, 10:41:34 AM »
Is there a standard code to put in the screen designer DRO to display a variable value that will be set via gcode #var?
Re: Display value of Gcode variable on a DRO
« Reply #1 on: December 11, 2013, 10:53:34 AM »
Not sure if there is an automatic way to do that, but you could always do it with a macropump.
« Reply #2 on: December 11, 2013, 04:33:13 PM »
There ARE some Dros that are cross linked to Vars I will try to look it up for you.
Rays way works for sure.
« Reply #3 on: December 11, 2013, 04:49:44 PM »
Here is the scoop, enter a value into either side and you will see the value on the opposite side of the cross link.
#Vars  15001 - 15255
are cross linked with
User Dros 1001 - 1255
(;-)TP
