Third party software and hardware support forums. > Sieg Machines
x3 Mill Homing Switch Install Question
(1/1)
wade16:
I have optical sensor homing switches on my X3 machine. My question is if I wanted to replace them with plunger limit switches, can I use the same wires that power the optical switch to power the plunger switch? Do I just transfer the wires to the connectors on the plunger switch to make it work? The reason I want to change switches is to obtain more X Y and Z travel without having to take the table apart to reposition the optical sensors.
cnc4pete:
Did you get an answer?
If not I can help.
How much more travel do you need? what is total travel?
Navigation
[0] Message Index
Go to full version
