Hello Guest it is November 07, 2026, 02:23:34 PM
Author Topic: MACH 3 and windows 7 setup and testing.Help!  (Read 9498 times)
« on: November 28, 2013, 11:42:52 PM »
Good day
I am building a desktop cnc machine for my self. i bouth 3 nema 17 steppers and a control board like image attached. but my problem is since my cnc machine has never run i dont kow if the problem is the wiring, Driver board , USB to LPT port converter , windows 7 or the mach software. so please can some one please help me on where to begin the setup of my cnc.
1) I have search online for wiring diagrams but every diagram i get the motors is wired up different, how do i insure i have them correct?
2) the driver board has dip switches, same as above every example i find they have been setup different. how do i insure correct operation ?
3) Mach software, after stating up the mach software it says "drivers initialized successfully" but when pressing the "reset" it keeps reporting emergency stop requested. how do i check correct  comport ? how  i check correct settings ? i saw when you even try and exit the mach 3 software and looking as task manager the Mach3.exe keeps running in the background
4) Does USB to LPT converter actually work ? if not how do you connect to the drive board form win 7 PC
any help is great! im at the point of giving up!
Re: MACH 3 and windows 7 setup and testing.Help!
« Reply #1 on: December 09, 2013, 05:06:11 PM »
I'm just a new guy myself, but I did get my mill running using a USB device attached to my Mac running Windows 7.
I use a UC100, check it out at http://www.cncdrive.com/UC100.html it works great and didn't need any setup beside installation.
As far as wiring, I used a Gecko 540, so my wiring was spelled out for me, if I were you I'd check out http://buildyourcnc.com/CNCElectronicsandWiring.aspx
Good luck, Marco.
