Hello Guest it is October 21, 2026, 07:33:09 AM
Author Topic: Acceleration problem  (Read 27461 times)
Offline moxy
  •  34 34
Re: Acceleration problem
« Reply #10 on: March 01, 2007, 05:56:17 AM »
Hi Brett, I just checked and a tab does it all Thanks
Les
« Reply #11 on: March 01, 2007, 06:05:29 AM »
 ;D
Offline Greolt
  •  956 956
« Reply #12 on: March 01, 2007, 10:26:11 PM »
I went to try the "FRO on queue" and had more problems before I even had a chance to see if that fixed it.
When in the middle of cutting the roadrunner (or any file I presume) if I hit feedhold then start
the router wanders off to some imaginary point in the distance and won't stop till it hits a limit or I stop it.
I have no idea whats going on here.  :)
Greg
Offline Greolt
  •  956 956
« Reply #13 on: March 02, 2007, 01:34:37 AM »
Further to this problem
I loaded up the latest version. No difference.
Discovered it is when scaling is used.
Turn scaling off and all it starts OK after feedhold
Greg
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #14 on: March 02, 2007, 02:23:53 PM »
Hi, Greg
Feedhold, Still has a lot of problems and is very very complex.
On your DXF files you can load them into LasyCam and scale them there.
You can size the Tab/MPG window down some by moving the left side over to the right, doing this several times with Tab-ing it open adjusting to same spot and closing, it will stay in that spot.
Hope this Helps, Chip
PS: Brett I have put the Fire trucks Back on Alert.
Offline Greolt
  •  956 956
« Reply #15 on: March 02, 2007, 03:51:43 PM »
In normal operation I spose you would generate your gcode in the correct scale.
However because I am only testing my new machine I have just been running the provided Roadrunner.
To get it to run at a realistic size on my machine I have been using scale.
However feedhold does not work when using scale.
Never mind,  hopefully I won't need it once I get going.  ;D
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
« Reply #16 on: March 03, 2007, 08:47:43 AM »
Hi:
 Feedhold on scale is fioxed now for the next version. Thanks for that report, I had never tried in in scaled mode..
Art
Offline Greolt
  •  956 956
« Reply #17 on: March 03, 2007, 02:58:23 PM »
Thanks for the report Art
That's great.  ;D
