Hello Guest it is October 21, 2026, 06:09:48 PM
Author Topic: Can anyone help me mach this work?  (Read 7813 times)
Offline mike^3
  •  116 116
« on: November 17, 2013, 10:27:02 AM »
Hello, I am working with a friend on trying to make the ATC lathe tool changer work, but it keeps giving me a compile error. Any help?
This is for my CHNC II SP Hardinge. Any Help would be awesome!!!!
'Macro M6Start ATC turret
Sub MovePos(ByVal ToolNumber As Integer)
OldTool = GetCurrentTool()
NewTool = GetSelectedTool()
TCtime = 0
ToolNumber = NewTool
If NewTool = OldTool Then
Message" Same Tool,  NO ACTION"
End
**MOBILE CODE**
If  NewTool > 8 Or NewTool < 1 Then
MsgBox" Tool # not a valid Number 1-10 ONLY, ENDING Program RUN "
DoButton(3)
End
**MOBILE CODE**
Xx = "-0.2" 'Tool Change position X
Zz = "-0.2" 'Tool Change Position Z
Code"G00"
Code "G53 X" & Xx
Code "G53 Z" & Zz
While IsMoving()
Wend
ActivateSignal(OutPut1)  'Deactivate Lathe Stop Dog
While Ismoving()
Wend
Message"Deactivate Lathe Stop Dog"
Sleep(1000)              ' Wait 1 sec for activation
ActivateSignal(OutPut2)   'Pop up lathe turret
While Ismoving()
Wend
Message"Disengage Turret"
Sleep(1000)               'Wait 1 sec for activation
Select Case ToolNumber      'Position to each tool number by input signal
      Case  = 1
        Do While Not Isactive(OemTrigger1)
         ActivateSignal(Output3)   'Start Air Drive
         Message" Start Air Drive"
                TCtime = (TCtime +1)
                        Sleep(1000)
            If TCtime > 10 Then
            Message" Tool Changer Timed Out, sequence ending"
            End
          **MOBILE CODE**
        Loop
        DeactivateSignal(output1)  'Stop Turret
         While Ismoving()
         Wend
         Message"Stop Turret"
         Sleep(1000)
        DeactivateSignal(OutPut3) 'Stop Air Drive
         While Ismovng
         Wend
         Message"Stop Air Drive"
         Sleep(1000)
        DeactivateSignal(Output2)    'Lower Turret to lock the tool
                While Ismoving()
         Wend
         Message "Engage Turret"
      Case  = 2
        Do While Not Isactive(OemTrigger2)
         TCtime = (TCtime+1)
         Sleep(1000)
            If TCtime > 10 Then
            End
            **MOBILE CODE**
        Loop
         While Ismoving()
         Wend
         Sleep(1000)
         While Ismovng
         Wend
         Sleep(1000)
                While Ismoving()
         Wend
      Case  = 3
        Do While Not Isactive(OemTrigger3)
         TCtime = (TCtime+1)
         Sleep(1000)
            If TCtime > 10 Then
            End
            **MOBILE CODE**
        Loop
         While Ismoving()
         Wend
         Sleep(1000)
         While Ismovng
         Wend
         Sleep(1000)
                While Ismoving()
         Wend
      Case  = 4
        Do While Not Isactive(OemTrigger4)
         TCtime = (TCtime+1)
         Sleep(1000)
            If TCtime > 10 Then
            End
            **MOBILE CODE**
        Loop
         While Ismoving()
         Wend
         Sleep(1000)
         While Ismovng
         Wend
         Sleep(1000)
                While Ismoving()
         Wend
      Case  = 5
        Do While Not Isactive(OemTrigger5)
         TCtime = (TCtime+1)
         Sleep(1000)
            If TCtime > 10 Then
            End
            **MOBILE CODE**
        Loop
         While Ismoving()
         Wend
         Sleep(1000)
         While Ismovng
         Wend
         Sleep(1000)
                While Ismoving()
         Wend
      Case  = 6
        Do While Not Isactive(OemTrigger6)
         TCtime = (TCtime+1)
         Sleep(1000)
            If TCtime > 10 Then
            End
            **MOBILE CODE**
        Loop
         While Ismoving()
         Wend
         Sleep(1000)
         While Ismovng
         Wend
         Sleep(1000)
                While Ismoving()
         Wend
      Case  = 7
       Do While Not Isactive(OemTrigger7)
         TCtime = (TCtime+1)
         Sleep(1000)
            If TCtime > 10 Then
            End
            **MOBILE CODE**
        Loop
         While Ismoving()
         Wend
         Sleep(1000)
         While Ismovng
         Wend
         Sleep(1000)
                While Ismoving()
         Wend
      Case  = 8
        Do While Not Isactive(OemTrigger8)
         TCtime = (TCtime+1)
         Sleep(1000)
            If TCtime > 10 Then
            End
            **MOBILE CODE**
        Loop
         While Ismoving()
         Wend
         Sleep(1000)
         While Ismovng
         Wend
         Sleep(1000)
                While Ismoving()
         Wend
End Select
SetOemDro(824,NewTool)
End Sub
End
