Hello Guest it is October 24, 2026, 05:12:35 PM
Author Topic: CS w/Brains & Triggers  (Read 62857 times)
Re: CS w/Brains & Triggers
« Reply #30 on: November 19, 2013, 02:32:16 AM »
Thought there was more to setting it up than that.
There would be if you were not using one of the CSMIO's, for the PP or ESS or....... you could only use one of Machs Inputs, so you would have to set that up and then look at that from the VB. CS-Lab however have added an extra layer in which you can look at any input to the CSMIO and then read its state direct from VB, likewise for OutPuts, you can set the state direct from VB without having to set up a Mach Output.
