Hello Guest it is October 21, 2026, 06:58:46 PM
Author Topic: Newcomer question soft limits  (Read 15879 times)
« on: November 12, 2013, 05:41:12 PM »
I cant seem to get my soft limits to work. I have entered all of the values in config as per instructions.
When I press software limits button, I get something like " Work outside limits " - can anyone help please?
Thanks.
Mike
Offline Bodini
  •  216 216
Re: Newcomer question soft limits
« Reply #1 on: November 12, 2013, 07:44:36 PM »
You prolly need to run the "Ref All Home" first.  Soft limits is for limiting the Machine Coordinates.
Reply for further help.
« Reply #2 on: November 13, 2013, 07:07:30 AM »
Many thanks Bodini.
I normally do a Ref All Home before anything else. I tried it again, but no joy. The full error message is:
"Machine out of limits for SoftLimit Activation.
I have in config (all mm)
X max 90, min 0, slow zone 1, %20
Y same as above
Z max -50, min 0 slow zone -1, %20
Thanks again for your help.
Offline Bodini
  •  216 216
« Reply #3 on: November 13, 2013, 07:23:40 AM »
try this:
Z max 0, min -50 slow zone -1, %20
Make sure your machine coordinates are between 0 and -50 when you try to enable soft limits.
Offline Fastest1
  •  920 920
  • Houston, TX
« Reply #4 on: November 13, 2013, 08:07:54 AM »
   Do you have limit or homing switches? Or are you "reffing all" with the table in a certain position? If the latter, is your machine running positive in direction from the ref point on X & Y? (Except Z whereas negative is a cutting move)
« Reply #5 on: November 13, 2013, 09:24:03 AM »
When you get the softlimit error, clcik the machine coordinates button ans tell us what the machine coordinates are.
« Reply #6 on: November 13, 2013, 11:09:41 AM »
Wow - thanks all ..... I will report back .....
« Reply #7 on: November 13, 2013, 11:40:47 AM »
@Bodini  -  I authorise you open one large, cool , beer and consume!
You guys operate a great Forum and one day I hope to return the favour.
Cheers (beer in hand)
Mike
Offline Bodini
  •  216 216
« Reply #8 on: November 13, 2013, 03:49:30 PM »
Great! Cheers.
