Hello Guest it is September 19, 2026, 04:52:53 PM
Author Topic: tool setter  (Read 14006 times)
Offline sdow
  •  67 67
tool setter
« on: November 07, 2013, 06:48:15 PM »
Hello
I never used the set tools  ....but have some questions ...  can i do that witch csmio and mach 3
i would every time when  mach3 ask me to change tools with windows pop (or similar processing ) to change tools manually   . After i change the tool and press ok .  The CNC go to tool setter  and continue the  process .
Thinks
Re: tool setter
« Reply #1 on: November 08, 2013, 07:52:27 AM »
If I recall the CSMIO/IP-S controller details tool setting routines and I think there is also a plugin available for download.
The routine will work equally for the IP-A, it is just there is no manual yet for it.
