Hello Guest it is November 03, 2026, 06:03:11 AM
Author Topic: Cut steps +Y .250 each pass  (Read 8262 times)
« on: October 30, 2013, 11:46:14 AM »
I am a noob with a Zenbot Mini , aftermarket controller, Artcam and Mach 3.
As the program runs the second pass moves approx .250" in the +y direction the the third pass moves another .250" and so on.
I have only cut pink foam so far so I have not trashed any bits , but I need to fix this before I try to cut wood.
Any ideas what may be telling it to shift each pass?
Re: Cut steps +Y .250 each pass
« Reply #1 on: October 30, 2013, 01:16:21 PM »
If you attach your xml and problem code I will have a look.
