Hello Guest it is September 28, 2026, 04:51:33 AM
Author Topic: Mach3 CNC3040 Looses Zero position after running code  (Read 7802 times)
Offline RoyT
  •  14 14
« on: October 30, 2013, 06:03:43 AM »
Hi
I have a CNC3040, ok its Chinese cheap machine but I am just a newbie diy user, which I have checked for any slack on drives etc and it all seems fine.
The problem I have is ...I position tool and set Axis zero's in Mach3 ..run the code ..then to change a tool I jog back to the zero coordinates on the Mach3 screen BUT that puts the tool about 25cm off ?
Any ideas please ?
Roy
Re: Mach3 CNC3040 Looses Zero position after running code
« Reply #1 on: October 30, 2013, 01:24:51 PM »
lower your velocity and acceleration and see if that helps.
