Hello Guest it is November 19, 2026, 08:37:14 PM
Author Topic: RESET A AXIS MACHINE COORDINATES  (Read 10336 times)
« on: October 28, 2013, 08:13:06 AM »
I want to set my A axis machine coord and work offset to 0, but when I do It sets a position to that a coord. when I then reset it it puts the # back in machilne coord..
Re: RESET A AXIS MACHINE COORDINATES
« Reply #1 on: October 28, 2013, 12:10:13 PM »
When my mach coord reaches 735805.9600 i get a fault.. I want to reset the mach coordinate on A axis without having to run it minus to get there.... for 735805.9600 degrees
« Reply #2 on: October 28, 2013, 01:02:17 PM »
Create a screen button with the code
SetMachZero(3)
OR create a Mcode such as M105 with the code
SetMachZero(3)
Run as needed where needed from either the Button or the Mcode call in Gcode or from the MDI.
« Reply #3 on: October 28, 2013, 06:43:24 PM »
I have it zeroed... thanks for the reply.... and answer
