Hello Guest it is November 13, 2026, 09:51:12 AM
Author Topic: Mach3 lathe manual control?  (Read 23815 times)
Re: Mach3 lathe manual control?
« Reply #10 on: October 17, 2013, 04:01:30 PM »
Handles or MPG's?
Offline Rimmel
  •  284 284
« Reply #11 on: October 17, 2013, 04:06:14 PM »
X and Z axis handles that manually control the servos
« Reply #12 on: October 17, 2013, 04:09:14 PM »
So electronic hand wheels (MPG's) ?
If so then maybe the feel and motion from them is ok but I certainly have never liked using MPGs for machining, maybe using ones without indents would be better, but better for me is use CNC :)
« Reply #13 on: October 18, 2013, 10:46:18 PM »
My MPG's don't have indents and are setup up ( counts per unit & velocity settings ) to somewhat provide for "turning" feel as if using a manual handwheel.
IE; turn slow and get small movements and turn fast and get faster movement of the axis. I think one turn of the mpg is around 0.008", thus great for positioning. I have used them to do some machining, but it takes a "heightened awareness" of what you are doing, thus it's just not as natural as say a manual handle since control can be lost and also there is no "feel" of the actual machining.
FWIW,
