Hello Guest it is November 26, 2026, 06:12:28 AM
Author Topic: Mach3 to VFD rpm difference  (Read 15935 times)
« on: October 16, 2013, 09:29:48 AM »
I am utilizing the 10 volts from my BOB to the VFD. If I control the speed from the VFD I can get the proper top speed of 24,000 rpm, but going thru Mach I can only get about 20,000. I know it’s going to be something simple, but I can’t find it. Any suggestions would be appreciated.
Thanks, Jim
Re: Mach3 to VFD rpm difference
« Reply #1 on: October 16, 2013, 09:37:16 AM »
Does your VFD have adjustment parameters to allow tuning of output speed relative to input voltage?
« Reply #2 on: October 16, 2013, 10:02:09 AM »
It very possibly does....but I wouldn't know where or what to look for. I am using one of those Huanyang VFDs, so if you (or anyone) have a clue where to find those (if it has it) please let me know.
Thanks again, Jim
« Reply #3 on: October 16, 2013, 10:33:24 AM »
Do you have the pulley speeds set correctly?
« Reply #4 on: October 16, 2013, 11:41:15 AM »
The pulley setup is:  0   24000   1
Offline Bodini
  •  216 216
« Reply #5 on: October 18, 2013, 09:28:26 PM »
Have a look here --> http://www.machsupport.com/forum/index.php/topic,18580.0.html
Worked for me!
Or it that's not applicable, there was a parameter in my VFD that was limiting the max speed.  I had troubles going past a certain RPM until that was set.
« Last Edit: October 18, 2013, 09:33:00 PM by Bodini »
« Reply #6 on: October 18, 2013, 11:02:33 PM »
If you could find/remember that parameter, that might help my problem.
Good luck and thank you for your response.
Offline Bodini
  •  216 216
« Reply #7 on: October 19, 2013, 12:41:05 PM »
I do not have that brand of VFD, so I can not help you specifically.  For the VFD I used to be controlled by Mach (a Fuji), it was the "Base Frequency" that was the problem.  It was set to 60mhz as default and it needed to be set to 300mhz.  300 is what jived with my spindle nameplate (a Teknomotor), so your mileage may vary.
« Last Edit: October 19, 2013, 12:51:50 PM by Bodini »
Offline Bodini
  •  216 216
« Reply #8 on: October 19, 2013, 12:44:49 PM »
Just had a quick look at the manual for your VFD.  Try changing parameters PD004 (maybe PD003 also).
http://www.2shared.com/complete/tvddak-F/HuanYang_VFD_user_manual.html
« Last Edit: October 19, 2013, 12:50:53 PM by Bodini »
« Reply #9 on: October 19, 2013, 05:57:23 PM »
Thanks for the info.....................
