Hello Guest it is October 24, 2026, 04:22:40 PM
Author Topic: outputs 4 and 5 on CSMIO  (Read 69904 times)
Re: outputs 4 and 5 on CSMIO
« Reply #10 on: July 27, 2014, 04:35:39 AM »
Please attach your xml,
« Reply #11 on: July 27, 2014, 06:07:45 AM »
Hi Max,
On this last screen. The plugin spindle screen. I would untick the enabled box in the Spindle DAC section. I believe this to be only for 0-10v dc analogue.
Then goto the MDI screen in mach and type M3S100 and see if the relay switches.
Alan
« Reply #12 on: July 27, 2014, 06:10:10 AM »
Hi Hood, was seeing how long it was before you came to the rescue.
The mach spindle setup and output signals tabs look ok to me when I compare them to my setup.
Alan
Offline MXJ
  •  19 19
« Reply #13 on: July 27, 2014, 06:23:19 AM »
Hi Hood
PM send to you
Thanks Alan
I will go and give it a go now. Will I still get the analogue signal to control the Super PID2?
Max
« Reply #14 on: July 27, 2014, 06:44:49 AM »
Hi Max,
In mach it should be 4 not 12.  In the output signals screen it should be port 10 which is correct. But the PIN number should be 4.
And your wire connects to pin 12 on the output header
Alan
Offline MXJ
  •  19 19
« Reply #15 on: July 27, 2014, 06:46:43 AM »
Hi Alan
I have un ticked the enabled box in the Spindle DAC section, but still Output4 does not change state
On the Mach 3 Diagnostics screen, when I inter M4, Output 4 lights up red, and it is slow flashing. Is it suppose to be flashing or is it supposed to be constant red?
Regards
Max
« Reply #16 on: July 27, 2014, 09:10:48 AM »
If you're using a Super PID, then you need to use two pins to control it.
You can use Output 4 to turn the spindle on and off, but you also need to use another output pin for the PWM signal which tells the SuperPID the rpm. This second output pin is what you need to enter for the spindle step pin.
On the Spindle tab, you also should be using PWM, and NOT step/dir
« Reply #17 on: July 27, 2014, 09:19:46 AM »
Actually, you might be better off using the analog 0-10V rather than the PWM signal, but you'll need some resistors to convert the 0-10V to the 0-5V that the Super PID requires.
Offline MXJ
  •  19 19
« Reply #18 on: July 28, 2014, 05:23:14 AM »
CORRECTION
On the Mach 3 Diagnostics screen, when I enter 'M3', Output 4 lights up red, and it is slow flashing. Is it suppose to be flashing or is it supposed to be constant red?
Offline MXJ
  •  19 19
« Reply #19 on: July 28, 2014, 05:26:50 AM »
Hi Gerry
I am using the analog 0-10V signal and turning it into a 0-5V signal via resistors
Max
