Hello
Guest
it is
November 14, 2026, 06:28:07 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Need some gcode help again. Using Ger's Screenset (but that isn't the issue)
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Need some gcode help again. Using Ger's Screenset (but that isn't the issue) (Read 21243 times)
ger21
6,295
Re: Need some gcode help again. Using Ger's Screenset (but that isn't the issue)
Reply #10 on:
October 10, 2013, 10:36:27 AM »
It's not the macros causing the problem, it's the way Mach3 is running them.
What version of Mach3 are you using?
Logged
Dbl_Tap
63
Reply #11 on:
October 10, 2013, 10:37:51 AM »
R3.043.066
Logged
Print
Pages:
1
2
Go Up
« previous
next »
