Hello Guest it is November 13, 2026, 04:44:45 PM
Author Topic: Problem with Mach3  (Read 31298 times)
Re: Problem with Mach3
« Reply #10 on: October 23, 2013, 09:21:36 AM »
Ok paste this xml into your Mach folder and use the loader to open Mach with it.
« Reply #11 on: October 24, 2013, 12:10:57 AM »
Hood-
That cured the running bad, and the freezing when it starts up.   I am going to leave the IPM set low until I get a few jobs finished.  After that I will try it back at 200 IPM and see what happens.
Did you see anything in my XML file that might keep the port 2 LPT address from saving?
I can deal with it if you cant find anything.
Thanks for fixing the freezing problems
Steve
« Reply #12 on: October 24, 2013, 01:53:49 AM »
What is your port address.
« Reply #13 on: October 24, 2013, 03:32:57 PM »
port 1 is  0x378
port 2 is  0xdd90
Steve
« Reply #14 on: October 24, 2013, 04:34:53 PM »
Dont see any problems with the xml as the address is sticking so not sure why you always have to re-enter :(
Problem with Mach3
« Reply #15 on: October 24, 2013, 08:59:09 PM »
Do you think it could be a hardware issue?
« Reply #16 on: October 25, 2013, 01:55:21 AM »
It could be but if software I am thinking it more likely that it is windows side of things rather than the Mach driver. Maybe check there are no printers set up to use that port in windows.
« Reply #17 on: December 28, 2013, 08:17:07 PM »
Scrambled /Hood
Not sure if this helps but I am having the exact same issue with my system running XP.  The computer sees the port configured but Mach3 will not save it.  I can change the address in Mach3 and then back again and it works until I reboot the PC.
I now enough about computers to be dangerous.  Could it be related to how XP handles IRQ or DMA settings.  I have never seen this discussed in the forums.
Jude
« Reply #18 on: December 28, 2013, 10:51:04 PM »
I had similar problem with Mach not saving the pp address. Was when i just got the new computer.
 If i recall, been a few years,   i uninstalled the card and reinstalled it and had to do that maybe 2 times before Mach finaly saved the address.
FWIW,
« Reply #19 on: December 29, 2013, 12:27:01 PM »
Rich,
Seems the consensus to remove and re-install.  I'll give that a shot and see if it works.
Thanks !
Jude
