Hello Guest it is October 20, 2026, 06:46:50 PM
Author Topic: X axes loosing steps, helps pls  (Read 21048 times)
Re: X axes loosing steps, helps pls
« Reply #10 on: October 09, 2013, 03:33:17 PM »
If your problem is the motor not being big enough to move the axis then going 1:1 will make it worse as you will be reducing the torque. Afraid I cant really say what you would need as each machine will be different as it depends on weight, friction etc.
 To be sure it is still not a motor or drive or computer issue you should really swap over components one at a time to make sure the problem axis is always the same.
Offline Robhi
  •  138 138
« Reply #11 on: October 09, 2013, 04:01:13 PM »
some times I think the problem comes from gecko drives. all gecko drives that I have are set to 11 o'clock. could I set them for more than 11 o'clock to have more current? if yes, do you think it will resolve a little bit the problem?
thanks
Robhi
« Reply #12 on: October 09, 2013, 04:12:49 PM »
Afraid I dont know anything about the Gecko servo drives, I have never used them :(
Offline Robhi
  •  138 138
« Reply #13 on: October 09, 2013, 04:26:13 PM »
ok Hood..thanks too much you are so kind..
thanks for all of you too.
Robhi
