Hello Guest it is November 04, 2026, 01:26:49 AM
Author Topic: help cnc 3020, executing the engraving from a mach 3 GCode help  (Read 10013 times)
« on: October 05, 2013, 08:19:31 PM »
 hello my name is Mike from Canada , im new to the cnc world,I have recently purchased a 3020 cnc router from china, the homing, and soft limits are set, the frustration is the tool path window. the work piece is outside the table view parameters, also when executing the Gcode generated from Photo V Carve the virtual tool path window and image looks and works fine, however the running cnc has little movement and no where the shape or size of the part
pls help. a new business depends on it
oh and one other thing the program and cnc did work properly and engrave properly, so something I have changed is the cause
thx in advance
  •  9,375 9,375
Re: help cnc 3020, executing the engraving from a mach 3 GCode help
« Reply #1 on: October 06, 2013, 07:22:19 AM »
Just a guess but perhaps you have changed the units from imperial to metric ? (Config / Select Native Units)
