Hello Guest it is November 23, 2026, 11:15:49 PM
Author Topic: Disable Generating Path on file load  (Read 7896 times)
« on: September 13, 2013, 10:53:04 AM »
Is there a way to disable Generating Path on file load? I am running Mach on a 3D printer and I am maxing out the specs on the laptop I use. File sizes are over 200MB.
If I hit cancel when the Generating Path dialog displays after the file loads, I can run the gcode without a problem. I regularly turn off the Tool Path display on these larger files as well.
thanks
