Hello Guest it is October 21, 2026, 04:11:22 PM
Author Topic: GREMLINS in the works  (Read 9305 times)
« on: August 11, 2013, 06:03:21 AM »
Hi there, after solving the PC problem by buying another PC, I have found some "gremlins in the works", I keep getting a re-set signal when running Mach3, error report shows "driver watch dog triggered" or "limit switch triggered" I can understand it if the cnc machine was even turned on but it is not even connected!!!! any one out there with any thoughts or ideas I would greatly appreciate hearing from you.
Regards
Nick   ??? >:D >:D
Re: GREMLINS in the works
« Reply #1 on: August 11, 2013, 06:32:01 AM »
Disable watchdogs in General Config and see if you still get errors.
« Reply #2 on: August 13, 2013, 06:13:07 AM »
 Thanks for the info ger21, it seems to have worked. ;D
