Hello Guest it is November 13, 2026, 08:08:15 PM
Author Topic: Mach3 Output For DC Motor Control  (Read 40612 times)
Re: Mach3 Output For DC Motor Control
« Reply #10 on: August 02, 2013, 11:12:58 AM »
Hi Tweakie,
I would be most happy to share my progress ( successes & failures ).
Thanks for Asking.
B.
"All of us together are smarter than any one of us"
  •  9,377 9,377
« Reply #11 on: August 02, 2013, 11:16:42 AM »
Absolutely true my friend  ;)
« Reply #12 on: August 04, 2013, 02:07:34 AM »
To answer your original question, the answer is that the PWM base frequency that Mach outputs is quite low. See section 5.5.5.2 of the config guide which mentions a value of 50 Hz.  But I am sure I have seen posts where people are using even lower, down to 20 Hz.  So smoothing the signal with an RC and applying the resulting signal to a conventional motor control makes more sense perhaps to give smooth running.  If you try the direct drive it would be interesting to know the results.
« Reply #13 on: August 04, 2013, 08:43:44 AM »
Hi Tweakie
I think that 50hz base frequency may be unusable, as I understand most systems use 10K or more.
I'm hoping that the base frequency is configurable in Mach3, see below...
I would like to construct a spindle motor speed control driver that will also operate stand alone, so I would'nt have to boot
the computer and launch Mach3, just to drill a hole. Also maybe a foot operated foot switch to reverse the spindle, for tapping threads...
Funny how these projects tend to sometimes expand on their own...
Cheers!
Bill
« Last Edit: August 04, 2013, 08:49:12 AM by PurpleThumb »
« Reply #14 on: August 04, 2013, 08:49:46 AM »
The PWM outputs, like all Mach3 outputs when using the PP, are limited by the kernel frequency.  The higher the output frequency, the less resolution you get.  With a 25kHz kernel, and 10kHz PWM frequency, you'd have less than 2 bits of resolution.  Some hardware motion controllers, like SmoothStepper, will allow higher frequencies, but I'd be surprised if even they supported 10 kHz.
« Reply #15 on: August 04, 2013, 09:07:03 AM »
Hi Ray,
I understand.
Could be the reason why no one ( as far as I know ) drives directly from Mach3.
I wonder what the lowest usable base frequency is?
What are the drawbacks of a low base frequency? Noise? Choppy Operation?
Don't know.
Thanks for posting,
Bill
« Reply #16 on: August 04, 2013, 04:40:15 PM »
Both of those.  And if you want to be independent of Mach for the odd hole then a standard motor controller makes sense.  It only needs an R and a C to smooth the PWM output, and maybe an op amp.  I use a KB motor controller and they are excellent ( though haven't got Mach controlling it yet).
